- Sep 13, 2020
- Texas
- 4.0 V6
- Total Lift
- Leveled out +1 inch at the front
- Tire Size
- 33 x 12.5 x R15 Baja Boss MT
- My credo
- For every door that closes another one opens for you to lead others always when you least expect it!
DONE!
The FOX 2.0 with Eibach 800lbs/inch springs did the trick.
Here we are with new lower A arms. The upper shock tower has the gussets welded in. I went with my own material for those gussets. I could get away with longer gussets on both sides. It was tight. I did have to grind to fit a tad bit as the test fit showed the coil spring to lower gusset was too close & may hit on full compression which I could not attempt. Also needed to relocate the brake holding bracket 1 inch forward. One important step to be sure to do is some initial test fitting with the shock fully assembled which was the first step. You can see the upper mount tilted to capture the upper Heim joint without excessive misalignment. These were primed and painted.
Kartek in Corona, CA https://www.kartek.com/parts/kartek...x-or-sway-a-way-58-34-or-78-shock-shafts.html
has the soft jaws required for installing the extended eyelets and both are required, not to mention a very heavy duty vise.
