- Oct 24, 2012
- Age
- 36
- Lafayette
- State - Country
- TN - USA
- Other
- 1978 Honda XL350 12v & Electronic Ignition Swapped
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Total Lift
- 4"
- Tire Size
- 245-70-R16
If you can't find what you need, I have seen shifters made with a single piece of flat steel cut into kind of a boomerang shape. Shifter knob on one end and a simple slot on the other. Add hole the pivot point. You loose the pull left to go to 4-low, but the transfer case still has detents internally.
