TRS 2021 Fall Off-Road Round-Up
Snoranger did, if I remember correctly. 12ish hours. Jim didn't include himself in the distance contest though. Ericbphoto and I were each in the 9-10 hour range.
Yeah, what he said. I drove just shy of 800 miles each way.
I can work on that. I'll need to take a gander at the frame tomorrow to get some ideas. I think I remember seeing some holes in the cross member just ahead of the transfer case I could tie into as well.
keep us posted and if you move forward, take pics along the process...good luck
Older trucks had t case skid plates, Ford may have left the holes.
I whacked that big refrigerator sized rock good twice on the first trail. I know the front diff caught it. Something around the neighborhood of the trans crossmember/t case skid plate also got it but I can't see any sight if anything.
How did I not notice a refrigerator sized rock?
The afore mentioned tank you drive...
It was like a big dorm fridge, way bigger than we grow rocks in Iowa as a general rile.
There are holes for the factory skid plate still there. I want to tie the plate with those and with the cross member in front of the transfer case. I was in a bit of a time crunch, so forgot to look for the holes I think are there on the cross member. I think it would be more solidly mounted tying those possibly imaginary holes with the existing holes forward and aft.
if that is the one going into the quarry, I just barely missed it. a couple of times I was able to go over it with the wheel instead of whacking it with the TTB...
AJ
AJ
I think you missed this trail. First trail we went on of the trail ride. It was on a pond.
Here are my pics. still need to sort videos out. Note Bobby Jr. and his accomplishment lol @bobbywalter
AJ
Observation for next year...
If you need a flag and have folding rear doors, the simple/cheap ones designed to go onto the top of your window will also work at the top of those doors. That way you can have your windows down and still avoid the hardware required for the bigger flags.
The flag that Badlands will bolt to the hitch hole in the bumper with two washers.
AJ
AJ
Thanks for the reminder that I need to remove the hitch from my bumper!
