- Jan 24, 2018
- Tallahassee Florida
- Total Lift
- Stock 2"
- Tire Size
- Stock
- My credo
- Doing things wrong, until I get it right.
You can use any transmission that will bolt to a Ford small block V8, that has never been an issue
The issue is with Manual transmission's shifter placement on the transmission
Earlier Trucks using the M5OD-R-2 behind 300 I-6 or 302 V-8 had the shifter farther forward, i.e. under the Ranger dash, later ones have 12mm bolt holes that need to be reamed for the 1/2" bolts for 5.0 (4.2 V-6 uses 12mm bolts).
Cars/Mustangs T-5 had the shifter farther back, between seats in a Ranger. Chev S-10 T-5 tail shaft housing puts shifter in exactly same place as Ranger's manual. So, you have to cross pollenate Mustang T-5 front with S-10 rear for ideal.
For Manual trans
The 1996-2003 M5OD-R2 from a 4.2l V6(same pattern as small block V8) has shifter in the same place as Ranger's M5OD-R1
Dang why not? It also has 351 heads. What headers do I need to get?It can't have a 351 intake.
So do I have a 302 or a 351? And will I need to get different heads to fit the rangerThe reason a 302 can't have a 351 intake is the 351 is a tall deck version of a 302 meaning the heads are the same (ish as noted by others...) but are pushed further from the crankshaft so the intake manifold is wider... which is why a 351 is wider than a 302...
I’ll take a picture of the motor when I have it on the stand. Here’s what it looks like rn lolView attachment 65420
That looks like a 351...So do I have a 302 or a 351? And will I need to get different heads to fit the ranger
