- Jun 25, 2021
- Age
- 50
- Abilene tx
- 3.0 V6
I'm having issue with occasional rough idle and engine hesitation under acceleration. Both tend to improve the longer its driven. The CEL starts off blinking, then goes solid.... Pulling codes p0316, p0300, p0174.... I've changed the plugs, wires, coil pack, cleaned the IAC and the MAF. Did a smoke test today and got smoke coming from the grommet at the pcv valve and from the top side where the pcv tube is by the throttle body. Could this be causing my issues. I tried to do a compression test, but COULD NOT get the tester to thread into the plug holes. I triple checked to make sure the threads matched, but it was like the tested thread would not reach. Idk if I needed an extension of what....
