- Mar 16, 2018
- Indianapolis
- State - Country
- IN - USA
- Other
- 1987 XLT 2.9 Ranger
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 2.3 (4 Cylinder)
- My credo
- Achieving nominal awareness, each and every day.
Rotated tires, found the rear lugs only had about 40 lbs of torque, the second time my tire shop screwed the pooch. I had lifetime free rotations so I usually let them do it, but no more. They also didn't center the wheel at alignment after I recently replaced the lower ball joints, and I had to take it back. They also didn't bother to report my effed up steering rack bellows at that time, either.
Flushed and replaced power steering fluid, discovered a leak at the return reservoir nipple, cracked reservoir plastic. Ordered another reservoir. Lubed passenger side caliper pins, was pulling a tiny bit left while braking. Still pulling left a bit.
I was getting what felt like minor ABS chatter braking in reverse, so I pulled the passenger WSS and blew some debris out of its hole. Too soon to report on that.
-Jazzer
-Jazzer
