Burnsy
2001 ranger 3.0 flex fuel...when truck is running theres constant vacuum to the heater valve......when I shut off the motor the valve doesn't release, the little lever on the valve stays engaged/sucked in, still under vac.....if I pull the vac line off the valve nipple the vacuum releases, otherwise its always under vac,......most people post with no vacuum, i have the opposite problem , thanks for your replies
