- May 28, 2018
- 41N 75W
- 2.3 (4 Cylinder)
- Total Lift
- It's up there.
- Total Drop
- It's down there.
- Tire Size
- Round.
- My credo
- I poop in the furnace.
Obligatory disclaimer: you can’t mix this stuff.
So my takeaway from the plethora of types out there, the 3 main American ones (used by many foreign males too) are:
Green (Inorganic Acid): Best for corrosion resistance for 2 years. After that it breaks down and becomes conductive making it corrosive
Orange (Organic Acid): Just fine, lasts longer, isn’t conductive, has sludg problems… i.e. DexKill
Yellow (Hybrid Organic): Nearly as good for corrosion as green, isn’t conductive like orange, and no sludge problems.
There’s others but I haven’t found dumbed down explanations of them. As far as I know, but can’t quite confirm, yellow is the best there is, has no down sides (maybe more $ than green), and every vehicle should be transitioned to it, especially if you have OAT DexKill. Green is fine, but I’m not going to remember to change it every two years.
Yes you should never mix coolant, BUT if starting from scratch you can run anything you want from a fresh start as you are not mixing. So using a HOAT coolant (zerex g05/Motorcraft gold) aka yellow is you best bet. You pay more up front but ge a much longer lifespan.
I agree though never put a stupid dexcool type in ANY vehicle you care about. Fine for GM vehicles...
Also the color doesn't mean everything anymore. Aftermarket companies like prestone sell "green" coolant in all types. The bottle will say what it actually is though. I put zerex g05 or Motorcraft gold in everything because they last, except in my mustang because I'm gonna change the coolant so often there is no reason for paying extra for long life gold, and my moms 2020 edge which has a strange new red coolant I can't even identify...
