Restoring coolant reservoir?
you also shouldn’t drink distilled water. it leeches minerals from your stomach lining and you’ll be susceptible to ulcers and such until it heals.
If drinking distilled water gives you stomach ulcers you ummm are probably already dieing from some horrific disease anyway...
That or you confused a glass of distilled water with tap water from Michigan...
Well I ran into an issue when I refilled my system. It seems that water can’t make it into the engine, running or not. The radiator fills up but that’s it. Cycling engine on and off seemed to balance everything out tho. My tstat jungle pin could be clogged and not letting any air out and causing an air dam type thing? Maybe undo a heater hose to let air out and fill engine most of the way?
