- Sep 6, 2018
- minnesota
- 4.0 V6
- My credo
- If youre gonna be dumb you gotta be tough
The truck is 1994 with a 4.0. Rebuilt the trans on it at 200k miles and the motor is probably next. Here's my list for a slightly better motor.
94 Ohv short block
Com cams 49-422-8
95Tm heads
Bbk 66mm throttle body
Melling high volume oil pump
Valve cover support tails
Crane springs #99858, 99835 or comp cams 988-16
Possibly make my own headers or pacesetter #70-1385
Plan is to find a decent lower mile 94 motor. Use 95-97 heads to bump the compression up to 10:1. Cam for the slight power and that nice idle. If my truck doesn't like the motor like that I'd use Jet tuning for my od1
Anything else anyone would add to the list?
94 Ohv short block
Com cams 49-422-8
95Tm heads
