lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
So I wasn’t exactly sure what to title this, but here’s where I’m at. I was surfing around on the web, think it was on a rainy day, and only like a month ago. Came across a thread or write up somewhere about the A4LD and it’s descendents the 4r44/4R55/5R55. Suggested the usual stuff, bigger trans cooler, regular flush/filter/fill, etc. Then it said something about how the shifts were sloppy which causes excessive heat and it can be easily fixed with a shift kit that can be installed without pulling the trans and a couple other tweaks that would improve performance and make it run cooler and explained the reasoning and all. Well, I read the whole thing, then left it as an open tab to refer back to. Well, I lost the tabs before I got back to it, my browsing history isn’t really a help, and my searches have come up dry.
A search for the shift kits has brought me two kits by Superior and one by Transgo. No idea which one was used or which one would be better. Wanted to try throwing one in the 92 and see what it got me, but no idea which to go with and why. My knowledge of the workings of these transmissions is rudimentary at best.
So I’m hoping someone would have some helpful information to share or be able to point me back to where I found it. I have scoured TRS in the past week and unless I’m blind or something, it’s not here. In which case I would like it here for others to benefit from as well.
