Various parts for free
Guanfy
Crawfordville, Florida
Stock
Stock
15in
I've got a pair of interior door panels from a '94 Mazda B3000. They are worn but not cracked. Passenger panel has most of it's mounting clips, driver panel is missing most. Pair of power mirrors from same truck. They again are used but work. Wire joining of some form will be required to wire into a vehicle as the connectors are missing. Pair of bucket seats from same vehicle. They are cloth and definitely worn. Some stains but no holes. Power bolsters still work on both seats. 3.45 rear axle from same vehicle, 170k miles on it. Works fine and still has the original drum brake setup.
I'm mostly looking to see if anyone wants any of this before I take it to the dump/scrapyard. I need to free up space in my house and my polebarn. I'm in the Wakulla County, Florida area. I'm willing to meet folks for local pickup.
62104
62105
Forgot to mention... I also have a gas tank from the same trunk. IT has a very small leak in it that I haven't had the time to isolate and fix. Since the tank is made of HPDE plastic it should be pretty easy to fix with a soldering iron and a source of HPDE plastic that you can "weld" onto the crack. Tank has been out for a long time so it doesn't smell. Local pickup only for that one though. Basically nobody will ship a used gas tank.
Would that 3.45 rear be better than the 3.73 I already have, and then would it hold up better behind a V8, than the one I already have. I was just going to use my 3.73's until the V8 broke it. ( if I ever get the V8 in the dam truck)
Also @Guanfy, How is that headliner holding up?
About the same, I didn't know if the mirrors or seats would do you any good since you are in the same state.
I met him before, we are like not even 20 miles from each other. I did his headliner for him. He got the cool quilted material and has one of the coolest headliners I have ever done. ( I've done about 10 )
I've ordered used tanks before off ebay, don't remember who the carrier was though.
Headerliner is doing great so far. A little bit of material has come loose of the glue in the front, but it's the cut bits that would have been glued to the back of the board. Everything else is fine. The 3.45 gear set is pretty gutless, but offers decent fuel economy for what our trucks are. I would stay with the 3.73 that you have so you can at least have the power to squirt a bit in heavy traffic situations.
Why would you buy a used gas tank?there not that expensive in new condition?
Because for those of us with older Rangers/B-Series, the tank is not made anymore. I had to drive 5 hours to get a replacement tank from a scrapyard once I determined my original one leaked.
What yr Mazda/ranger do u have?
Mine is a 1994. It has a plastic tank that I couldn't find anywhere. Had to buy used.
