- May 15, 2020
- Age
- 70
- Atlanta
- State - Country
- GA - USA
- Other
- Manufacturers factory tour, maybe big dealership tour
- 4.0 V6
- Total Lift
- 97 stock, 3” on 87
- Total Drop
- N/A
- Tire Size
- 235/75-15
- My credo
- Never put off ‘til tomorrow what you can put off indefinitely
What about taking the roof off the last 30-40’ raising the walls up 4ft, and adding a 30ft wide addition extending towards the house, and then putting a roof across all. Building would be “L” shaped, with 2/3 at the higher height. You’d pay for 3 walls and the roof.
If you go metal, the erector can put a steel sill plate along the alley-side wall, and span all with steel trusses. You could tear down the house side wall and have it all a clear span, maybe a couple posts in the middle.
Also, I don’t think either of the block walls where the original building ends are structural, but the one by the bathroom has plumbing in it. If you come 4-5’ off the block walls towards the front and poke a hole in the ceiling and get another rafter picture there, I could make a better guess ;-).
