- May 15, 2020
- Age
- 70
- Atlanta
- State - Country
- GA - USA
- Other
- Manufacturers factory tour, maybe big dealership tour
- Vehicle
- Ford Ranger
- 4.0 V6
- Total Lift
- 97 stock, 3” on 87
- Total Drop
- N/A
- Tire Size
- 235/75-15
- My credo
- Never put off ‘til tomorrow what you can put off indefinitely
What do you guys think? I think if I can throw another 10 or 12 drawings and ideas at @Jim Oaks , I can make his head explode before noon tomorrow!!!
@franklin2 video: it works, I’ve done it, I wouldn’t do it here, IT WILL NOT WORK HERE! Why? I zoomed in on the picture, see below. They’re lifting points are on the bottom of “W” trusses. It is not a rafter roof. A rafter roof is framed to the top of and secured by the wall, it does not just sit on top of it, so you would have to box in the ends of the rafters, and then lift it from just inside the walls. By the time you did all of that, you can tear the roof off and put the trusses up easier. The hydraulic equipment in the video is expensive even to rent, and the tall jeep jacks could work, far less stable than the hydraulic system with a steel frame.
Let’s look at an offset truss:
This sketch shows you all of the 2 x 4 cuts at the correct angles. Everything on top is done by the half, and everything below is done by the third. Having done it once or twice, I would line up the peak of the roof with the peak of the original roof, and let the side that goes over the bumped-out wall run long. If you do an 8 foot bump out, and you allow 1 foot overlap in front and back for the rain drip, you end up with a 30 foot trusss.
I’m an engineer, and I can tell you the math would make you absolutely crazy to try to draw out all of the angles and cuts. There is a very very simple trick I learned from a carpenter. If you look in the lower left corner, you really only need two dimensions +3 1/2 inches. “A” is the overall length of the truss, and “B“ is the overall height of the truss. Note the 3 1/2 inch rise on either end which is the height of the bottom 2 x 4. With those two dimensions, simply put five dots on your concrete floor, and snap chalk lines. Mark all the 1/2, 1/3 spots and then lay the 2x4s on top of the chalk lines and mark them to cut. It only takes a few minutes to lay out one, and then you have your templates for all the others, and simply put them together laying over the same chalk lines.
You can have half inch gaps between the two by fours and it doesn’t matter. The plywood plates screwed in with glue are what carry the strength. Yes, my 27 x 45’ shop is put together with Elmers glue!
Here are pictures of my plywood plates, you can see that they’re not straight and square and they don’t line up with the edges of the 2x4s. I intentionally put the plywood plates inside the outside edges of the truss so they wouldn’t get in the way of anything when we were assembling it. The screws are wallboard screws. They only have to hold the plywood down long enough for the glue to set.
