- Aug 17, 2007
- central ohio
- 2.5L
- Tire Size
- 235/70/16
- My credo
- the grey-t escape
sounds like worn spiders
Interesting comment.They definitely are , strangely enough only when towing. I can load the bed with 1400lbs of tools and supplies and the truck rides fine but the same 1400 trailer weight will be slow going up a steep hill. I wouldn't change the gears if I never towed but I move my boat around with the truck a lot and occasionally tow materials on long drives (8hr+).
I was going to suggest Super Swamper TSL/SSR Radial 27x9.50R15's, but if you wanna stick with what you have, that's fine.That's why my Bronco 2 is sitting on 235/75R15's, nobody has the right size tires anymore for them....at least nothing in a snow rated tire, yeah you can find a few all season tires but I want 1 tire that'll handle the snow/ice and backroads. The Cooper Discoverer AT3 4S tires on the Bronco 2 now handled the snow/ice this winter very well and I bet if I aired them down a bit they would do even better, but didn't get but 1 snowstorm this winter that required a little 4WD use and it was 10 inches of snow so I never had a chance to air down and try that out, but at 40psi the tires had plenty of traction and in 4WD no tire spin at all, very little sliding on ice either...yeah sure if you just stab the brake as hard as you can like an idiot it'll slide of course but driving normally and modulating the brakes it does great. Would love to try in some deeper snow hopefully next season when I can go up north if they don't cancel the McCall, Idaho Winter Carnival again because of COVID...ugg... I have been here for 30 years, I have never been able to go to that carnival, I just mainly want to go to see all the ice sculptures, but I love the scenery up there in the winter too, tons of great photo opportunities.
I don't think I'll be doing any gear swaps as nobody makes 4.10 gears for the Dana 28, and I'm not swapping to a wider axle just for a gear swap, my Bronco 2 is stock so it'll go pretty much anywhere you can take one of those $30k UTV's and some of them I swear are wider than my Bronco 2 is now, don't want it any wider I like it as it is.
The 3.73's do OK, I don't drive it on the freeway anyways so its not that big of a deal running it at 65mph on the highway between home and Boise, ID and back, but any faster than that and no thanks LOL. My Ranger does the freeway at 80mph extremely well, and honestly haven't even taken the Explorer out on the freeway yet, no need to, don't drive to Boise very often, and there's nothing I need that requires use of the freeway. Which is one thing I don't understand why so many people keep moving here to Emmett, Idaho. Boise is 30 miles away, there isn't a freeway within 40 miles of Emmett no matter what direction you go, its all 2 lane highway, and backroads in and out of Emmett...and most of the orchards are gone being replaced with over-priced houses with no land house takes up the whole dang lot type thing with many of these new subdivisions....out north of town where I'm at an acre is as small as they'll divide, and I'm wishing I still had the 2nd acre from my place. Someday I hope to be able to buy it back, even if I keep the back house as a rental I want my 2nd acre back LOL.
One of my nephews used to work at that resort out in McCall a few years back. Ended up managing the restaurant portion, then took over a sushi place that was also in McCall. Had to come back here because his girlfriend's dad got sick.
I think he works in Seattle now.
...and thank you for getting the "You-don't-have-to-go-60mph-on-every-road" concept.
I tell folks not from here that I (and most people who grew up around here) are happy doing 60 on the freeway, especially since I only use it when I'm running late.
They're likeI'm like
Right on, brother.![]()
I honestly don't think I'd want a limited slip. When a wheel spins on a open diff you have the other wheel to keep the back end located sideways. I find that if I have weight back there it has fine traction.
The sensor reads the ring gear speed. The ring gear has to spin at XX RPMs to turn the tires at XX RPM. It doesn’t care what RPM the engine is at to get there.
Yes.So you're saying my fuzzy thinking on the subject is correct? If the sensor was in the transmission tail shaft as they usually are, it would've needed to be adjusted. But being in the differential, it doesn't care. Nice.
