1984 atc125m
I'd just go through it. It's stupidly simple, and 99% of the time, the float needle valve is the only thing that needs replaced. Unless the float bowl has a gasket that rips.
I can go through a Honda carb from start to finish in less than 30 minutes easily.
I use brake clean, being careful to not spray it on o-rings or gaskets. I clean it with an old toothbrush with the tip ground thinner. I pull bristles from a brass brush to clean the tiny air and fuel ports.
If you like to clean the outside to look like new, the Harbor Freight "suction style" soda blaster works like a charm for that.
As for the carb being for a bigger engine, if you can get the jets at a local cycle shop, just drop the size of the main jet one size and that'll likely take care of it. Or look up the jet sizes for the 90 and switch to those. If your exhaust is more free flowing than original, then the 110 carb will probably be fine as-is.
GB :)
I haven't even really looked at the carb other than to make sure it had one when I bought it, it is still hanging on the throttle cable on the trike in the barn.
Well anyway, I was changing the furnace filter before the big freeze and poked at it while I was down there. Jeeze, I need to just get this thing together, the side cover is corroding terribly.
1984 atc125m
So I dragged it upstairs and hauled it to work to play with at break. IIRC (I need to go back thru this thread) I just needed a gasket kit to throw this on, change the rocker arm cover to fit in a 110, pull the flywheel and solder a wire for the armature over there and the base engine is done. Then I need to play with the carb, clean the fuel tank and in theory it should run/drive.
1984 atc125m
I need to go look for numbers, the good engine is a 90 and I don't know what year it is.
I get this one done then I can pull the engine out of the wife's, totally explode it and change the case on it.
I had a atc 200 for a few years, was a lot of fun but nearly wore out. Smoked like a 2-cycle (it wasnt) Last fall I came across a yamaha 3-wheeler, thought about it but they wanted $1,000 for it. Id rather have a3-wheeler than a quad.
Three wheelers ain't cheap, especially the big ones.
Depends where you are in the country. Cali seems to have a killer trike market where a 200x can be had in running rideable condition for around 800 bucks. Up here in maine.. that same trike would be 1200+ IF you could find one.
Its why I'm building my 200x from parts lol. Itll be a bigger initial ivestment.. but im gonna end up with a MUCH nicer rig that won't need any more work for a good long while hopefully.
Not sure why, anything decent is over a grand here. Why my $150 110 is kind of a pile...
Oh yeah, side quest. Dang corn fuel just sticks to everything!
1984 atc125m
You can tell by how clean and dry the exhaust port is that this is a pretty fresh rebuild too. :yahoo:
Anyway picked some corn...
1984 atc125m
Sandblasted and cleared the rocker cover/motor mount
1984 atc125m
1984 atc125m
Went to install this cover... and the screws just fell in the holes. The holes in the drum are stripped... yay.
1984 atc125m
1984 atc125m
So I hauled the 110 parts motor over and pulled the drum off of it
1984 atc125m
Rocker cover is on, gasket surface is clean, case is cleaned out... ready to assemble tomorrow?
1984 atc125m
Getting there!
Can I have that corn?
Sorry, you took too long. Somebody else already spoke for it.
"new" clutch installed with better oil filter plate and bearing.
1984 atc125m
All the clutch bits with the oil director installed:
1984 atc125m
More clutch bits plus new gasket:
1984 atc125m
After installing the side cover I checked the valves, intake was a little loose, exhaust was right on. I went back and forth and ended up using the 90 cover, I will probably have to adjust the clutch. I ended up judging by the total lack of care the 110 received the clutch would need adjusted either way and I had already stuck the 110 back together before I thought about the clutch adjustment being in that housing.
1984 atc125m
In theory... ready to run?
1984 atc125m
Pulled the armature out of the 110, I need to fix a wire on it and then I think the 90 is complete enough to run minus the carb which I pulled off the trike over the weekend so I can go thru that.
1984 atc125m
Also tried to pull the chain out of the 110, it seems jammed in the case around the sprocket and since the engine is seized I can't really force the sprocket to turn easily. If I could pull the flywheel I could take the cases apart... looking closer and noticing the jackolantern tooth situation on the 110 I think if it runs halfway decent I will just snag a new chain.
If you look carefully at the pictures, you might be surprised how many parts are on ebay. Those engines (and some axle parts) are compatible with much of the chinese 110-125 quads. It's fairly common to swap whole engines into older Honda frames. I wouldn't even be surprised if a little work could get one the quad rear fender sets to work.
I have been drooling over a new Lifan as I don't have super high hopes for this 90. Like $480 for a new 140.
Kick start and I won't have the hi-lo though. :unsure:
Big concerns are while it feels like it has decent compression how shot the engine is and if I can get the armature/magneto to work. There doesn't seem to be any option for retrofitting a later CDI ignition on these things and the chinese stuff is totally different (crankshaft taper etc) so that can't be retrofitted either.
I see armatures from time to time on ebay for $100, they don't look much nicer than what I have and have about the same guarantee.
Those points covers look suspiciously like the one on my 78' XL350. It converted to CDI easily with an ATC185 ignition pickup and China Z50 clone CDI module. I did order a spacer from John Ayscue.
I asked for just the spacer and bought the rest of the parts elsewhere.
Just make sure the CDI is correct for your electrical system. AC (has it's own wire from stator) is most likely since it has points now. DC would only have a wire coming from the battery/charging circuit to CDI. If you can make the pickup fit, you can run either one. DC can even be run on just the battery.
Edit: Just thought of something. What about swapping the crank to use the chinese stuff? Could go for one with more stroke at the same time if it exists.
If I go that deep I would probably start over, who knows what else got changed. I could see that turning into building a later/Lifan one piece at a time.
I did come across a thing where the Lifan kick starter interferes with the rear fender badly but there is a place that sells a pullstarter kit (more $$)
I think the problem with the ignition anyway is they cloned a later engine, my 90 is a generation older than what they cloned.
And my 110 engine/trike is a '79 so no dice there.
