lil_Blue_Ford
Cut & Weld
⭐Supporting Member
💻 TRS Socials
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Total Drop
- 4”
So yesterday we got done with work early so I decided to address my 4x4 issue in the 92. First order of business was a quick and dirty patch job to the extended cab. Took a piece of thin scrap aluminum I had, made a bunch of TLAR (That Looks About Right) cuts and bends, pop riveted it on, sealed all of the edges with foil tape and despite being way cold, squirted some red paint on it.
Then I moved into the cab to address the module... pulled the connectors, hit the test switch multiple times, well, sometimes it would click once and a slight flash on the LED, sometimes nothing and only once did it click a bunch and flash a couple times. Might try opening it up and see if there’s any chance of rehab for it. Went looking to see if I could find one of the spares (I had either one or two). No luck in the one parts pile and no luck in the lower level of my shed. Climbed up into the loft and was debating where to try digging when I realized I was looking at what appeared to be the back of a module in front of me. Flipped it over and yup. Really expected it not to work because it’s never that easy for me, but I put it in and it clicks like it should. Going to try and come up with a spare or two though plus other parts. Really would rather have the lever through the floor. Maybe someday.
