2008 Explorer, How To Remove Instrument Cluster to Replace Burned Out Bulbs
wildbill23c
Southwestern Idaho
215/70-R14
How do you remove the instrument cluster on a 2008 Explorer to replace burned out bulbs? Looks like the bulbs for the fuel gauge and coolant temp gauge are both burned out or they did a lousy job of illuminating them. Can't see either one at night even with the dimmer turned all the way up.
Your cluster is a newer version than my 2001 ExST,
but likely still need to start by removing the dash center panel & knee panel under the wheel
before you can pull out the instrument cluster & get to the bulbs on the back. Try a youtube search "2008 explorer cluster lamps"
Several links listed here on taking apart\repairing lamps in the 2001 dash; hope it helps.
Thats what I did. Thanks though. Actually a lot easier than my Bronco 2 and Ranger LOL.
