Update on my 88 Ranger SAS
Depends on the Engine. 5" exhaust is about right for a 500hp Diesel. Way overkill for most gasoline engines, but it depends on the application.
except we arent talking about a 500hp diesel...:D
It's just a fancy exhaust tip. It's up to him to do what he wants. If he wants to run vertical exhaust ending with a large stack, then he has a right to do so. Doing so does not make his truck less capable or turn it into being shoddily built. It's really no different than painting a tube chassis or rollcage bright green or pink.
:icon_twisted:
:icon_twisted:
plus all that ads about 20 HP :icon_welder::icon_hornsup:
especially the high temp paint. I almost blew up my 7.5 after painting it. the wheelie was worth it though.
cut fenders
flat black rattle can paint
pic of truck a couple days ago
now, decided it would be easyer to just take the body off to do the 302/zf 5 speed conversion
that pic of it together is without motor/tranny and all other metal stuff. it sits a bit lower with it all in... and i want to put a d60 and 42s on it eventually so i need a lil more lift then average
NICE TRUCK, i'm doing the same thing to my 88 supercab . did you buy the leaf spring mounts as a kit somewhere ,or did you fab everything? i'm putting in a d44 from a 68 f250 as soon as i go through the rear and inspect and replace everything while its on the ground. any extra info or links would be helpful.
i made almost everything
heres some pics and links for you...
http://www.ballisticfabrication.com/
http://www.ruffstuffspecialties.com/
http://www.polyperformance.com/
i am probibly going to redo my shackle hangers i dont like my design i can just see it braking under all the weight... it might not, but i thought of a better idea (thats if i dont convert back to coils)
UPDATE on my ranger for those who care,
installed
302
zf-5-speed
hays super brute clutch kit
boxed frame from front end to end of cab so far
