Overdrive INOP
Pilot Laslo
Oklahoma
Hello
My overdrive button doesn't work, whenever i press it the O/D light does not illuminate. I have checked with multi meter and the button does work correctly. Any suggestions of where to check next?
Thanks
At highway speed, can you feel tranny OD engage\disengage when toggling the OD switch in the shift lever?
If it does engage\disengage, then the OD switch+wiring in the shift lever & column is OK, likely a bad bulb in the instrument cluster.
If the 2002 cluster bulbs have never been changed, it's time to do that, as you've likely got other bulbs that are out or ready to go out.
Info on dash & cluster maintenance at
Info on steering column maintenance at
Hope this helps.
Each time you turn on the key all dash "warning/indicator" bulbs should come on, its a BULB TEST
Does OD OFF come on?
If not bulb is burnt out
OD button gets 12v key on(fuse 2,cab), its not an on/off switch, its a momentary contact switch
The Switch's other wire runs to pin 29 on the computer
When computer sees 12v on pin 29 it toggles OD off or on, which ever it was it changes to the other
When computer boots up OD is always ON, there is no "last state" memory
So when you tested the wires you should see a key on 12v wire, and then 2nd wire that is 12v only when button is pressed
I really hate to cast doubt on anything RonD says, given how much I've learned from his posts, but that is not true on my 2004 Ranger and may not be true on your 2002.
That linked thread has other information that may prove useful. In fact, if you have an OBD2 scantool and Torque Pro or FORScan, you might want to check out my last post in that thread.
[...] 2004 is an HEC dash(1st year in Rangers), full digital cluster, it has a Test Mode you can access to do bulb and guage tests [...]
Thanks for the clarification, Ron! And sorry to the OP if I caused any confusion.
I don't want to derail the OP's thread, but I read up on and (extensively!) tried that HEC test mode several months ago and was never able to get it to work on my 2004 Ranger, despite having tried everything I could (including watching 2 videos of people doing it). EDIT: I should probably open a separate thread to discuss it at some point. New thread: HEC Test Mode on 2004+ Rangers
Correct me as needed, but I believe
199?~2003 Rangers\Sports\SportTracs have the older NonDigital\NonHEC cluster, at least that is what's in my 2001.
PreStart BulbTest flashes most of the cluster lamps, but not all; it does NOT test the ParkBrake, TurnSigs, 4WHi, 4WLo...
That's why I did not go there in my response above.
50731
50732
