I6 swapped b2
The 300 is a hell of a inline, 4.0 x 4.0 , same as the 400 V8. Heavy motor to put in a ranger (or ranger-based) chassis though. I loved my 4.0 ohv, had 235’s and 3.73’s. The best V6 ever though? the gm 4.3 , im a ford fan through & through but taking 2cyls off a 350 made quite a good motor. But as GM does, they axe a good thing and long gone is the S-blazer & the 4.3 V6. If I were to do a engine swap, Id just go with a 302, a 289 would be enough but they are scarce. I need a decent enough chassis for that first, Been eyeing the non-running reg cab stepside across the road from me.
300 weighs less then a 302, and makes torque way lower.
I thought they weight almost the same.. within a few pounds.
To muddy the waters more I think they are heavier. A 2.3 isn't that much lighter than a 302.
I was searching around, can't find exact number compairison from ford. However, it seems like the 300 is 60-70ilbs lighter. 380 ilbs empty, and 450 ilbs empty.
No. Thats 2.2L of metal they forgot to drill out of it. It has to be heavier.
You might want to double check the math before you quote him.
The larger the displacement, the more air is in there, and the less it weighs.
Allow me to add to the confirmation of this theory...
If I want to build a 306, I take a 302 and bore it .030 over. Yes, That would only remove a small amount of metal but it’s also a small increase in displacement. So, according to our current hypothesis, a larger displacement would require even more metal to be removed making the engine even lighter.
Exactly.
