- Oct 6, 2019
- Age
- 38
- Auburn, Wa
- 2.9L
- Total Lift
- 4” body lift
- Tire Size
- 31x10.50R15LT
So, I’ve done some work.
RV Camshaft
Bored +40
4 hole injectors
Cat delete
Headers
Small stroke (idk where the machinist found the crank, but he did.)
I’m also running Advanced Timing and driving on 92 octane, it runs like garbage on anything lower than 92.
Now, I’m assuming I’m needing to have my computer adjusted cause this thing is running rich. Not rich to the point of falling on its face, but rich enough to throw codes and lose a little bit of power when I get my foot in it.
I should also add that I’m running a 170 thermostat, I just think 192 (recommended) is too dang hot. Idk if that would effect it running rich though.
I thought about getting the Jet Chip for it to see if that helps? Been tossing around the Morana dual upper intake.. Also, been looking at a bigger throttle body, or custom intake setup. All I know is I need more air. I’m confident I’m sitting between 175hp-185hp, until codes start being thrown lol.
I’m just having a hard time trying to decide what to do. Any ideas would be appreciated, as long as it doesn’t have to do with a damn swap.
The engine just broke 2500 miles, so swaps are out of the question for now. I’ll also add, I’m trying to break that “Mythical” 200hp mark.
To give you an idea of what’s going on here, I’m running 31x10.5R15 and she’ll break them loose through 2nd and chirp into third.
help me get loose through 3rd please (jk) and stop throwing CEL
But seriously, let’s talk.
RV Camshaft
Bored +40
4 hole injectors
Cat delete
Headers
