OldCowpoke
An old Ranger came home after being given to Sister several years ago. While driving about 50 miles from home it started losing power then would not start. Replaced Fuel filter immediately as fuel line from tank was loose at filter, replaced filter won't start. Opened air line to fuel system and sprayed starting fluid in no start. Placed inline spark tester on spark plug wire, no spark. Inserted spark tester between coil and distributor - no spark. Checked 12 VDC to coil with ignition key on - Good -replaced coil - still no spark. Tested throttle position sensor, 0 to 5 VDC when manually activated. Check engine light comes on when key is turned on and can hear fuel pump build pressure when key is turned on. WHERE DO I GO FROM HERE???????
