I removed the PS and AC mounting brackets. When I pulled this bolt out. It was coated in oil and little bit ran out.
MadMax_636
Georgia
2.8 V6
However much it goes up when I get my fat ass out.
How much it goes down when my fat ass gets in.
Dry rot and old
So, besides my other thread about doing the duraspark mod. I removed all my dead power steering and AC system. I removed the brackets and mounting systems for the PS and AC.
When I removed this bolt. It was coated/soaked in motor oil and a little bit of oil ran out. I put the bolt back in.
Do I need to put washers on this bolt to make it clear an oil port?
Is this above or below the fuel pump? I can’t tell what I’m looking at in this picture.
Its above the fuel pump.
I do not believe this to be a through hole—but the best way to tell is to remove the bolt and put a screwdriver or Allen key in to check. I was afraid it was below and someone had replaced the oil pressure switch with a bolt.
Yeah, that would have been scary! Its above it and its where the PS and AC mounting brackets bolted onto. Since Im deleting that stuff. Just making sure this ONE bolt that BLED oil could be put back in all of the way.
Ill do that test you said before I fire her up. Just intake it is. I don't want to plug some oil port up....
