Can The Windshield Wiper Cowl be removed on a 1993 Ford Ranger
Angry Possum
No Fat Chicks, Truck Will Scrape
Law Enforcement
Staten Island NY
N/A
Total Drop
N/A
Sometimes you eat the bear, sometimes the bear eats you.
I have a water leak in the front passenger area of my 93 Ranger. In what I have researched it's most likely in the windshield wiper cowl. Can that be removed or is it welded to the body?
Its welded in
But unlikely to be a leak point, but possible
Lower corners of windshield trough is most likely if its running down behind the kick panels or corners of firewall inside the cab
But yes if you use a hose feeding water only into the cowl area and get the leak to start then under the cowl it is
Cowl area drains on each side just in front of the doors, check that it is draining on each side
Most common leak point on Rangers is the 3rd brake light on the back of cab, and because a Ranger usually sits a bit higher in the back the front areas get the water build up, and if its parked most of the time slightly leaning to the right then front passenger area
And, of course, if you have AC then clogged drain causes water in the passenger side footwell
Its welded in
When I ran a garden hose through the access panels for the cowl, I had actually seen some water droplets on the front passenger kick area where the passengers feet would go. So I don't think it's the 3rd brake light. And further, the water was draining on both sides of the cowl.
You can pull off the Blower motor to see if the water is leaking in from Fresh air vent, its under the area of the cowl with no holes, it has about a 1" lip around it so water in the cowl can't come in(unless drains are blocked), but it can rust
There is no filter so its just an open vent the blower can pull in fresh air from
Basically what Ron said... if you were really spraying a lot of water in there it could have run over or dripped through the fresh air vent but that might not be your problem. Could be rust in there, could be leaking somewhere else. The windshield on my Explorer leaks, water comes in somewhere on the bottom of the windshield and then runs down behind the dash and drips on the pedals. Maybe narrow it down with small amounts of water poured on specific areas.
I think the only access you have for a cowl repair, if that is the leak source, is to pull the dash and any access openings you might have on the firewall.
Since it's on the passenger side, there should be a water drain on that side for the A/C. I'm not sure if non-A/C trucks have that drain as well. That could be clogged with debrise and causing the system to fill with water and over flow.
No blockages in the cowl drain now, I used a leaf blower and then a garden house to clean it out via the 2 access panels. Water came out of both sides of the cowl drain, so I'm assuming there isn't any blockages in the drains.
If you have A/C, there should be a water drain for the evaporator that would be separate from the cowl drains. This is there to handle condensation running down off the evaporator since it sits lower than the cowl drains.
I don't remember if my non-A/C equipped Ranger had that drain as well or not.
It would be a rubber hose running down under the cab that may or may not have a fitting on the end to keep insects from crawling up into the hose.
I'll check my AC condensation hose. Thanks
PS: Ever since I have been going to a car wash at least 3 times a week, especially when the roads were salty, I have noticed this water anomaly under the passenger car mat.
That sounds like the condensation drain. I had that problem wifh a Honda CR-V I had. I think I fixed it by running a wire coat hanger up the hose.
Thanks again, I'll check it.
