So I want to swap a 302 into my 83 ranger and I’m thinking about using the T5 transmission but I want to know if I can use 4wd with it. Do I need a special adapter? Is there a T5 that can fit the transfer case ?
I would much rather go with the 5.0 V8 but why would you recommend this one because it is easier for 4wd?M5r2 from 97+ f150 with 4.2 v6 is your best bet.
The Essex V-6 (3.8, 3.9 & 4.2) has the same bolt pattern as the Windsor V-8 (255, 289, 302 & 351*). So, a M5R2 bolts to back of your 5.0. And the M5R2 plugs into the hydraulic clutch of your Ranger - same slave cylinder as the M5R1. Lastly, the M5R2 has a 3.97:1 1st gear; useful for a 4wd truck.I would much rather go with the 5.0 V8 but why would you recommend this one because it is easier for 4wd?
Its ok, I think both first and reverse are a little on the fast side. In low range it is a beautiful thing on a trail though.
The 4.2 does have metric bellhousing bolts. Like 12mm. A 302 uses 1/2" bellhousing bolts so you do have to drill the holes out to so the 302 bolts will fit.
I used R1 clutch hydraulics (all of it) and the clutch kit for a '96 F-150. If you use a '80 or older 302 you could use the clutch stuff for a'96 F-250 to get the right balance. You also need the starter (which will need a little wiring change) and engine separator plate from a Windsor V8 R2. The starter hole is smaller for the V6 (and other transmissions too) I discovered this after I had it put together and went to put the starter in it, I dremelled it out and it works but it was a PITA.
