Hope this is the right section to post. I'm just learning about cars so forgive my ignorance. I need some help to pass smog -- OBD is still not ready - oxygen sensor, oxygen sensor heater, evap, and cat are not completed. Expired tags for over a month so far
I have gotten a new battery and have completed a few drive cycle attempts since then, maybe 3 ( looked at the ford drive cycle) after the new battery, about 200+ miles. Driving stop and go and at 55 on the freeway with hazards on, in socal... Smog guy checked the Fuel trim and STFT on both banks were identically +12.5, so running lean. He said maybe a vaccume leak, i have visually inspected vaccume hoses/lines, the PCV valve was replaced like 8 years ago, but have not checked this with smoke yet. There are no codes. Months ago i had a p0102 code but i replaced the MAF and cleaned my K&N air filter and it did not return. This was all pre - smog attempts, so im thinking i should clean the new maf again b/c of the fresh K&N oil in the air filter...? Maybe I need more drive cycles? Im gonna replace the cigarette lighter fuse just in case and get a new radiator cap. Any suggestions? Opinions? Truck has 97,000 milles and starts up great every time idles at under 1500 rpms at first ,then dips to around 1000, it vibrates a little but not a violent shake or anything.... no check engine light. Runs fine as far as i can tell but i dont drive that much. Thanks in advance for any tips. Hoping I don't have to just scrap my perfectly fine running truck because OBD monitors wont ready.
edit - I started the car and unplugged the IAC and the idle dropped to just above 500 rpms, like 600 rpms-ish - does this indate a vaccume leak as well?
