- Nov 6, 2008
- 4.0 V6
- Total Lift
- ~10
- Tire Size
- 35
I've purchased a Jet reprogrammer. There was no option to adjust the speedometer, I called Jet and they told me my firmware was out of date so I went to Ford and had it updated to no avail. Then I actually took it to Ford to see if they would do it and they told me there were only set groups of tire/gear ratios and my truck is currently outside those ranges(4.56 gear, 35" tires).
This led me to this product called yellow box from Australia. It's a device that is supposed to act as a digital gear reducer. But after hooking it up all I got was a trouble code. I tried the abs signal and the PCM to instrument panel wire.
I checked the forums here but all the products listed are no longer available. On a side note, if any one needs a speedometer recalibrater I have one to sell. Go to yellr.com to find out more.
