- May 27, 2019
- Ashland City, TN
Wondering if Ford offered an Automatic with the 4.9L in-line 6 cyl 4x4?
If so, what tranny was it
The 4.9l(300) I6 used Windsor pattern, same bolt pattern as small block V8s, i.e. 302/351, so should not be hard to find
AOD was used up to 1993, after that is the AOD-E which needed a computer hook up, but AOD-E was used as earlier at 1992 in trucks and vans, so heads up
1991 and older would for sure be AOD only
Don't forget flexplate
And starter motor, I think it was different for automatic
I looked at South Bend - they certainly have several options. Knowing nothing about how strength and durability relates to “Foot Pounds”, is the higher the FP the more HD?Luk makes a heavy duty clutch. Seems to work pretty good.
But if you’re going to invest in one good clutch. Look into south bend clutch’s.
