1993 F150 4x4 4.9L 5spd to Automatic
SCK
5+ Year Member
Ashland City, TN
Wondering if Ford offered an Automatic with the 4.9L in-line 6 cyl 4x4?
If so, what tranny was it
I don’t know for sure but that year in automatics Ford offered the AOD, E4OD, C6.
Yeah, I've seen a few 4.9/auto combos. They were all AOD or AODE. Most were Econolines, but there were a few F-150s.
The C6 was mostly a big block trans.
The 4.9l(300) I6 used Windsor pattern, same bolt pattern as small block V8s, i.e. 302/351, so should not be hard to find
AOD was used up to 1993, after that is the AOD-E which needed a computer hook up, but AOD-E was used as earlier at 1992 in trucks and vans, so heads up
1991 and older would for sure be AOD only
Thanks Ron! I really appreciate your help.
Pull-a-Part here I come!
Don't forget flexplate
And starter motor, I think it was different for automatic
Yes. The cone is longer on the auto trans.
Manual starter won’t engage the flywheel on an auto
I’m finding out there are several “additional” items; steering column w shifter, transmission cooler and lines, larger brake pedal, etc..
Is it worth it investing $1k+ in a ‘93? Just asking myself.
If you were closer. I’d swap you all my auto stuff from my 95 for your manual stuff.
  • Like
Reactions: SCK
Maybe a different direction... I’ve been hard on the clutch. I’ve smoked it several times while in reverse when trying to back a loaded trailer.
Would a HD clutch (if there is one) make any difference? I know what all y’all are going to say, “ be easy on the clutch, learn how to drive ?” and so on.
Comments?
Luk makes a heavy duty clutch. Seems to work pretty good.
But if you’re going to invest in one good clutch. Look into south bend clutch’s.
I looked at South Bend - they certainly have several options. Knowing nothing about how strength and durability relates to “Foot Pounds”, is the higher the FP the more HD?
Is a HD clutch rated a 240fp harder to engage than one with lower FP?
Have you considered just backing it up in low range?
The higher the FT-LBS the clutch is rated for. The stronger it will be.
Yes theoretically a heavier duty clutch will be stiffer. But that’s why I like south bend. There clutches are smooth and light.
