Junk Collector
⭐Supporting Member
Truck of Month
Here's my crossmember collection - '85 Bronco II, 88? Ranger, '91 Ranger
Yeah, just one hole on each side.
I also discovered that it has almost no brakes, the driver's door needs hinges and a striker post real bad, and there's a rather large water leak happening on the driver's side floor.
IIRC there was more than one style of "early" crossmember and it depended on what trans you had - I THINK that the one I have pictured came from the same B2 that my C5 came out of... but I have had it a LONG time and probably parted out several '85 B2's, so who really knows now.
Where was your water leak coming from? Cowl? Mine's plugged up full of pine needles.
How'd you end up fixing it? Can I remove the trim and squirt a bunch of urethane in there? I have two 1988s that leak there... my '86 stays dry but the dang sunroof I put it drips quite a bit![]()
I may still have the tube bumper and grille guard behind the shed.
I'd be interested in the tube bumpers/grille guard if they aren't rusted out. My '91 STX had them from the factory per the window sticker but were removed by the previous owner due to rust... I still have the factory Roll/Rallye bar though haha but its missing the lights![]()
Few things:
Unless the truck was mint/clean original, I doubt (as much as I don't want to because I'm a huge fan of them also) a High Rider STX is worth much more than any other 4wd to 99.99% of the population. It's just a cool oddity.
2nd, on the crossmembers what I have noticed (excluding the early 1st gen stuff) most rangers (pretty much all 4 cyl & majority of 2.9/3.0) from the mid-late '80s to late '90s have the bushing style trans crossmembers. The solid mount "L" style crossmember is always found in 4.0l RBVs. I've replaced the bushed crossmember with the "L" style crossmember in every one of my trucks as its a much better design (no bolts seized forever in the bushings...)
3rd: RBV frames starting in '92 (yes starting with the last year of the 2nd gen) are boxed/crumple zone design all the way to the engine crossmember. Basically '83-'88 are identical, '89-'91 are identical, & '92-'97 frames are identical.
Although the fixed yoke 1350 transfer case is very rare, it doesn't have as much value as a 1354 (especially a manual).
I've personally removed a set of the factory lift brackets/springs/pitman arm from an extended cab '89 STX in the junkyard and installed them on my '91 2.3t 4x4 swb truck.
On a side note, if you're interested in selling the front sway bar from the truck I'd love to have it for my '88 GT.
