MadMaxZuki
- Mar 26, 2018
Hello everyone, I hoping to find some help on this. I have a 2005 Ford Ranger Edge 4wd 4.0L and I just recently replaced the thermostat housing and its components. This is my 3rd ranger but first 4.0L. I was under the impression that one is a sender and one is a sensor. I put it back together and had the connector with the green wire on the sensor and the other on the sender and my gauge pinned to hot instantly. So I took it apart and swapped the connectors every thing seems to work fine. Now I have an engine code of "coolant temperature low circuit input". The catch is what I took out was two temp sensors, not one of each with no engine codes for the few hundred miles I put on the truck. Does anyone have a educated answer on what is happening or if my specific year does not use a sender? If it does have a sender then I would start by replacing that. Thank you
PS
I am not trying to come off confrontational but I am looking for an answer not opinions please. I have a bad taste from other forums in the past for the bad habit of people giving suggestions to everything but the question being asked with no expertise backing up their opinions. I'm hoping this forum is different considering how through and helpful your website has been. Thank you in advance.
PS
