- Aug 11, 2007
- Age
- 69
- Ontario, Canada
- My credo
- Love Thy Neighbor
Providing an update got everything back on and the truck starts but shuts right back off were thinking its the fuel pump or something of that nature i've already taken off the bed and hopefully its the fuel pump relay is working but my dad doesn't here a sound coming from pump. any other scenario would cause it to cut on but shut back off ?
the fuel pump will only turn on for a few seconds and if you're not hearing anything you can try swapping the relays...if that doesn't work then it could be the pump is pooched. You can remove them and test in a bucket with fuel in it...there is a risk to that so be careful not to spray fuel all over the place...like I did a few times...lol
If it is starting but then dying it could be fuel pressure issues...pump not turning on or maybe inertia switch is tripped. The inertia switch is on the firewall inside...near the passenger side...I think we went over that though.
If you have a vacuum tester you can use that to test fuel pressure...just use the valve on the fuel line on the intake side...if it is under pressure you should wear eye protection when working on that...see if there is pressure there.
