bobbywalter
TRS Technical Staff
TRS 25th Anniversary
Ugly Truck of Month
- Aug 9, 2007
- woodhaven mi
- Total Lift
- sawzall?
- Tire Size
- 33-44
- My credo
- it is easier to fix and understand than "her"
depends on chassis and where you want it.
I clocked mine a little flatter when I put the diesel in because I had to set the diesel lower to get to my boa goals and body lift equivalence targets.
the 208 is so easy to work with I ran it to get going, figuring a doubler or atlas before 10 years went by....
...... come august it will be 10 years my platform has been diesel.. been on front leaf 11 +....
I have tore quite a few up. so I suggest to get a pile of them.
if you find a jeep unit or two that are drivers drop, with a 2 in lift it is a cake job to fit.
but the bronco case will likely require you to roll the engine a bit and bias it to the passenger side 3 in off true center.
