- Aug 14, 2007
- UT
- 4.0 V6
- Total Lift
- 5
- Tire Size
- 33
Steering wheel on-off switch does nothing on the ohm meter when the on button is pressed. So I get out the volt meter (next step in the service manual) It calls for approximately 7.8V at the switch with the key on, I have 7.7 so I think I am good there. When the on button is pressed it should go to 12v when the cruise is armed... and mine does nothing. So I think I need a switch, so that is on ice for awhile until one turns up in a yard.
Did you ever figure this out?
I actually ran into the same problem on my cruise control install earlier today. Your truck may not be the same, but I wasn't getting 12v at the amplifier when pressing 'On' either, but I was getting 7.8. Turns out the power for that comes from the horn relay, it's a yellow and green wire. The yellow and blue supplies power to the relay and the dark blue one powers the horn itself.
If yours is different then.... Idk.
