1988 ford ranger starter solenoid wiring
Mightyfordranger
Ohio
3in
Clean your room before you criticise the world.
Left terminal:
Positive from the battery (shown here is the thick black wire i had to replace mine)
The yellow one runs to the main harness on the inner fender
GREEN this one runs to a another harness that runs toward the headlights next to the battery
(The little red one is for my cb i added)
Right terminal:
This runs to the back of the starter
Little red one on top:
This comes from the same harness as the green one next to the battery
Sent from my SM-G930P using Tapatalk
positive from starter
ground from one starter bolt to a common on the frame
The point of this is to show correct wiring of the starter solenoid on a 1988 2.3l 5 speed 2wd. Was hoping a mod could add this somewhere how ever they see fit
Great pics of the wiring...although yours is a bit rusty...lol
I'm not sure if you've ever seen this but there is a form and process that anyone can use to post articles for submission. It can be a bit overwhelming if you've never done it but it is worth the time and effort...especially if they use the document in the Tech Articles section.
You can review that here...and it might not take long to just post a few pics but I'm not familiar with tapatalk or whether those images can be used...may need to be hosted...I think a Mod would need to expand on this more...the images are fine the way they are and maybe they can just put them in the 4 banger section as a sticky...or whatever...I won't say any more because it may be too much work added to someone else's schedule...
anyway...review the process for your own use and maybe you have some hosting in place that would work for you.
http://www.therangerstation.com/forums/showthread.php?t=147332
I did not know there was a form for that and...and yeah their a little crusty but thats ohio for ya ill have to rub some die electric grease on em and all i have is my phone for internet right meow
I always carry a wire brush with me...and some of that spray on silicone stuff that works good on battery connections to keep out moisture. Or some Vaseline...that was my Dad's favourite and he was an electrician so I figured he would know about that stuff.
I think after he bought a cabin cruiser and dealt with the electrical system on that it became a must have addition to his boat toolbox.
Nice pics :)
Its a Starter RELAY, lol, my pet peeve
But every one calls it a starter solenoid
A solenoid creates motion when activated
A relay connects electrical circuits when activated
On some starter motors there is a hump and that IS a starter solenoid, when activated it pushes out the starter gear to engage the ring gear, so creates motion
So you make the call, on what that fender mounted unit is :)
Nice pics :)
Doesn't make much diff to me lol just trying to get the info out there for folks
Since we've already started down the technical verbage road...
A relay is a solenoid linked to one or more sets of electrical contacts. The solenoid part provides the motion to move the contacts open or closed.
Agreed
Yes, all relays that have moving parts were called solenoids, but very very old school, like 23 skidoo, or Funky, your choice, lol
Transistors are "relays" with no moving parts but are called.........transistors
So we have a Battery saver Solenoid or Head light Solenoid
Hey up to you really, I am Groovy with either term, just pointing out the differences in my opinion :)
Hey up to you really, I am Groovy with either term, just pointing out the differences in my opinion :)[/QUOTE]
Same here. And I do realize my comment left out solid state devices.
Eric B
Eric B[/QUOTE]
how can they be called solid state when they turn things on and off??? :dunno:
at least Fleming Valves got the terminology correct, as they adjust the flow.
