PlumCrazy's F-1Fiddy Build
Small update. The lowering shackles turned out to be a disaster...they were too long, so I shortened them up, then found they were too wide, then found the bed support to be in the way and on shackle bolt stuck....so I bailed.lol
Ill just hold off until I get the front down 2" and then flip the rear axle for a nice level look.
I went out to Carlisle and and had a blast this past weekend.
Few road shots from the drive out with 036speed
while I was there I picked up a few items on my shopping list.
92-97 8 lug beams and big brakes for my 8 lug swap. Rotors, pads, calipers, balljoints are are in great shape, so basically just bolt in and go once I get a decent set of 8 lug Alcoas. He also gave me the steering linkage and sway bar. All the joints are Moog and the radius arm brackets are OEM Ford
I plan to go lowering beams eventually...but I may try running these stock 8 lug beams, 1/2 ton coils and no spacer/sway bar mount...this should get me down ~ 2" up front and still be able to get camber in spec....with 2" up front I can drop the rear 6" (via axle flip) and sit about level (tires just inside the fender well) Id like to get a little rake so that's where 3" beams would be nice. When I go beams, I plan to use the stiffer 250 (PSD) coils to stiffen up the front.
I would like to figure out a helper spring setup or bags out back to help when loaded with a trailer...When I have the bed off for paint I may build a gooseneck hitch so I can build a light duty goose trailer in the future.
Also pickup up a nice crack free set of 5.0 manifolds, just one stud froze in the y pipe flange to deal with.
Not related to this build..but I bought a lightly used JD2 tube bender as well. Has 1" dies with it, but Id like to get few larger setups as well.
Like most of my projects...this one isn't moving too fast either.
I did finally get my OEM driver fender from my southern supplier...
Hoping to get the front clip on and the new bed on in time for paint this year..
I have been putting the old truck to work this year though. The ZF and hydroboost making hauling grain with a half ton almost more enjoyable than the F350
Drug 10 or so loads up with it to keep things moving this year..Dad and I both work until 5pm and the grain terminal is only open until 7pm, so we have to hurry home and hope to yank 2 loads each in before 7 so that we can run the combine for a few hours each week night.
My copilot was keeping me company in the Chevy too..
Havent been turning wrenches much on the trucks..but I did talk to my paint guy today. Plan to hang the new panels/bed by the end of the year and drag it down to him.
Also...these showed up last week.
The ole girl is getting old. Rolled the big 100K last week. Turns 30 years old next year....saw 60K in 27 years...and 42 in the last two.lol
Current plan...hang panels, send in for paint, bolt up the drop beams, swap in the 8 lug 8.8 and flip the perches, then drop it off for tint....Id like to be done by next summer.
That is a darn nice truck. I love the 80-86 bodystyle, probably my favorite Ford body. Dad had a '80 F-350 4x4 SRW, it was a cool truck. It was closing in on its third "big 100" when he sent it down the road though. :bawling:
It needed cab corners, rocker panels, an engine and a clutch, otherwise she was good to go. :D
He replaced it with a '96 2wd 460 truck with the ZF5. Originally had 3.55's but the rear was ran out of oil before we got it so we regeared it to 4.10's since its main purpose is to pull a gooseneck. Still has kinda wonky gearing, first is way low, second is too high and reverse is still plenty fast. At least it has OD though, the T-18 in the '80 really needed that one extra gear. The '80 had 4.10's as well but could comfortably start out in second unloaded.
My ZF5 and 3.08s is a great setup for daily driving..especially for monthly OH to NY trips....but I plan to regear to make it little more trailer friendly. I have 4.10s, 3.73s, and 3.55s to choose from. Leaning towards 3.55s for now.
Sent from XT1030 using Crapatalk
Man that's a nice truck.
I am super jealous of the bender. I really need to just buy one already.
You people need to tell me when you are gonna be in Carlisle!!!
Ill be there for the Truck Nats next year again....as will 036speed and OneBadEx I assume. Thinking Ill hit the all Ford show next year as well.
Yeah, I usually make the Ford show, but I was out of town that weekend this year, and I'm hit or miss on the others, but I just moved back into that area and live like 8 miles from the fair grounds now.
Made some progress this weekend.
Stripped down the mint core support I scored way back.
PORed it
Wire wheeled, PORed, and undercoated the new bed, swapped it out for the one on the truck. I left all the trim, bumper, and tailgate hardware off for paint.
The worst part about pulling the old bed was cleaning out the toolbox so we could lift it....lol
Put the abandoned F250 chassis to good use.lol
tore the front clip off to swap out the rotted core support.
bolted up the new rust and damage free fenders.
cleaned out all of the pine needles plugging the cowl drains
And gave the Dingo a new bed...
Early Christmas present from the Mrs....NOS front wheel moldings. Still need a pair for the rear, and not certain if I will like them when its all done or not.
Also drove out to OneBadEx's place and brought home this turd nugget for a new DD.
BTW..PA has bridges with 6' 6" clearance...
Replaced the nasty headlights, and mounted up my my old CRX snow tries on some cheapy wheels from Sloth69Mustang. Also picked up a blown out XL bench for the Ranger to work on rebuilding. I cant stand the Expo buckets that are in this thing... no room to move, especially when there are two people and a dog in there.lol
I know where that bridge is... Why on earth did you take this route to Nick's??? :icon_rofl:
Never saw this build thread. I remembered you had the C4 when I saw this think up at West Co. That ZF-5 has to be one hell of an improvement :icon_thumby:
I took 70 to the 31(?) exit, it made me go around like eighteen loops and turns..then put me on a little windy road with a 6' 6" bridge. I skipped that road on my way home and popped out at the 70/31(?) exit from a different angle.lol I fit just fine empty, but loaded was going to be an NG situation.
Pulled the lights, handles, trim, etc. and hauled the turd off to the scrap yard....
Just kidding. Dropped the truck off at the body shop. Next time it sees daylight it will be sporting a brand new dark blue metallic coat.
Sandblasted, painted, and cleared the tailgate hardware.
I dropped the truck off with a rear roll pan to get it painted....still not sure if I actually want to ditch the bumper though...but figured Id get it painted now anyway.
The new DD got some love too. Timing belt, plugs, wires, T-stat, and new fluids.
I think the belt was ready.....30K ago.lol
Also made some badass mud flaps since the brackets were already there with no flaps.
Also scored some Husky Liners from Santa!
I swapped out the cluster for one with a tach and swapped the HVAC panel, headlight switch, etc to green as well. I am looking for a Stock radio that lights up green. It has to be the older style plugs on the back...PM me if you think you have one an we can discuss.
I have a few stock Ford double dins, but they had "Premium Sound" so the connections are way different on the back.
Picked up a rollpan for the 150..im going to have it painted now, but not sure if ill end up using it or not.
Got to few teaser pics too. Color looks different in person. It is a very close match to the factory blue, just a little more flake.
