bobbywalter
TRS Technical Staff
TRS 25th Anniversary
Ugly Truck of Month
- Aug 9, 2007
- woodhaven mi
- Total Lift
- sawzall?
- Tire Size
- 33-44
- My credo
- it is easier to fix and understand than "her"
she was hazey mc tazin pretty good.
any kind of mpg numbers for an all around average?
i have been punishing my 6.2 pretty hard. it would pull that tractor, just slow and even more smoke. though with a turbo it would run like a beast pulling a tractor like that.
work has slowed a bit so i dont want to pop the coin to install the turbo...but i found a place called mandrel bending solutions with a very hard to pass up builder kit that has me on the edge of sayin f-it and spend the coins.
http://mandrelbendingsolutions.com/builders-kit-aluminized-steel-not-expanded/
it might be sort of a waste the way i want to do it, but i would like to build a system that wont require removal to pull the engine.. a tricky task with a v8 diesel in a ranger engine bay to say the least....plus i been wanting to do an ac system.
i have looked at some b2,s lately and some more dub motors,
between the jeep kits and toyota kits i think it wont be too bad to do a tdi swap in a b2 cost effectively. i just have to decide if i want a e350 with a cummins as a daily driver or a b2. my ranger is my daily driver but i really want to change it up and that will require a bunch of time and money....a bunch more then fixing up the b2 for personal use.
my truck mpg is down from 15-19 to 13-17mpg....though i run 40-60 percent oil blends with that so cost wise its like 22-26 mpg. i think the b2 with a hand shaker and even with 33 in at radials could beat that handily.
and since i see alot more dub guys running oil blends my interest has been roused again.
do you think your going to offer any adapters?
