Power mirror switch question
bn6339
Hello all,
I searched a bit and couldn't find anything directly related to my questions: First, is there any aftermarket source for a 1994 power mirror switch? I've found about a million (or maybe a thousand) listings for post 1995 rangers, but nothing for a 94. The other question is would a 1994 Mazda B-series switch work, or is it different? I figure that would be my other option as I am rather averse to paying 100.00+ for a mere switch....please advise, and thanks!
I was told that the 95's are the same as a 94. Can you post a picture of the underside connector to see if they are the same.
Here is one for the 1995 Rangers. $15.00 at Rockauto
http://www.rockauto.com/catalog/moreinfo.php?pk=4672089&cc=1138025&jnid=546&jpid=0
I believe the connector may be the same (I haven't removed the door panel to check) but according to some diagrams I saw the wiring arrangement is a bit different. I will probably remove the switch at some point and see if there's a part number I can obtain....thanks for the reply!
