- Jan 31, 2009
- Boston, MA
- 4.0L
went around a wet corner and revved it a little spinning the tires. the engine died. I was able to start it and get it home. runs rough. Pulled those 2 codes. fuel pressure is 65 psi. I did a little searching says it could be intake gaskets or a big vacuum leak. all thoughst encouraged. TIA its for the 2004
. I just got a misfire on #4 and pulled the plug . it appears pretty worn. The plug in there was a MC AGSF24N. All the store had was an autolite APP 5144, I threw that in. I want to get them from rockauto, plugs and wires. Rockauto has nickel plugs and these AUTOLITE Part # XP5143 Iridiums. Any thoughts?
