I can't believe that one can paint outside at all.
What about dust?
What about dust?
What about dust?
Looking real good, Jeff. I know you're going for a stock look, but I think the black diamond headlights and matching corner lights would look awesome with that mirror black paint job...
SVT
Dang, that's coming together nicely.
I like the stance. Your careful consideration of ride height, wheel width, offset, and tire size really fill the truck out without looking cartoonish or sticking out from the body obscenely.
I hate it when people slapdash some rims on their vehicle because Cousin Vern gave them some, and the fitment is so poor it's laughable.
Just because the bolt pattern is the same, doesn't mean they should be mounted. LOL
Heaterbox and pedals stay in, lower the steering column, remove the fuse box door on the driver side door jamb, there will be a bolt at the lower corner dash above the E brake, another just inside the fusebox, the lower corner of the right side, remove the panel on top the dash near the windshield, there's 3 bolts there. Near the center of the dash on the floorboard, to the right of the throttle pedal, there's an 8mm bolt that the support rod/bracket is bolted to, remove that. After that, the dash will be free from the firewall, might have to wiggle it a little, but it'll come free.
If you are removing from the truck and not just pulling it for access, unplug the HVAC vacuum feed from the firewall, and the electrical plugs through the firewall near the E brake. 95-11 ranger dashes (95-01 explorer) are structurally the same...
SVT
