1999 5.0L Mountaineer Build - SAS with Tons
Well its huge and its home. Going to see what I can do with it. Thank you Plumcrazy for getting it home to me so I didnt have to drive my truck.
2005 D60. I got all the steering links, track bar and calipers with it too.
Next to a 79 D60
That big fancy shop you have doesnt have heat? Slacker...i know its cold i start work again monday :bawling:
Nope, No heat. I just a wood burner that doesnt do much with 14 foot ceiling and no insulation...
Looks good! Bet itll look even better under the mountaineer :)
If you don't use the factory coil mount, i need one...
SVT
SVT
I will keep that in mind. There is a 90% chance I wont be using them.
Located a rear 2006 10.5 and a manual 4406 case cheap. Double digit cheap. The problem is that they are 470 miles away. The good thing is that they are 10 minutes from my sister-in-law. So my bother-in-law is going to snag them for me this weekend. Next time we go visit, I will bring them home.
I think i hold that record wizkid lol.
Looking forward to seeing the build start. Finally warming up here
Thinking out loud.
Current Inventory (for this project):
2005 front D60
2006 rear Sterling 10.5
SBF 4wd ZF5 with clutch and slave
SBF NP435 (bought for this but not using)
BW1356 case
BW 4407 case (I guess its not a 4406. But I still want it)
Hydro assist steering ram
(8) Johnny Joints form YJ project.
Yukon D60 reverse cut 5.38s
Hard parts needed:
Wheels
Tires
Rear gears
Lockers
Pair of coil overs
Flywheel
Ranger pedal assembly
A bigger master cylinder
Smaller fab parts:
Lots of tube
brackets
And I still have a Jeep to part out.
Thinking out loud.
2005 front D60
BW1356 case
Hard parts needed:
Wheels
Tires
Rear gears
Lockers
Pair of coil overs
Flywheel
Smaller fab parts:
Lots of tube
brackets
Keeping leaves out back for now?
That 2016 goal seems closer than when we set it before....lol
Sent from my XT907 using Crapatalk
Leaves can still work very well. Nice set of deavers and your good.
I know what you mean with deadlines i wanted mine done for july just added up the new parts i need its 6g worth of junk.... and i already have most of what i need.
