Recently replaced the clutch, I used a Luk clutch kit with new clutch, pressure plate, pilot bearing, throwout bearing, new Ford slave cylinder, had the flywheel resurfaced and changed the tranny fluid with Mercon V. Also replaced the tranny mount as both bolts snapped on removal. Other than that everything went smoothly.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
