1993 4.0 oil pan unbolted won't come loose
poor ole blue
Blue Grass,IA
I am getting ready to bust my aluminium oil pan ! Every bolt/nut has been removed . Timing cover is off . I have a tiny gap by timing cover end as I get towards tranny it gets tighter . Any and all ideas Welcomed !
You may have to undo the trans bolts a few threads and split them to get the oil pan out.
I have never tried to pull the 4.0 pan in-vehicle, but the Focus 2.0 has a similar full-depth pan, and the trans a engine have to be separated a few mm to get the pan to come free. The back end gets wedged.
Shoot brother
The couple of minute that will take sure beats buying another oil pan thats for sure . Thank you !
Well I did find a hidden Torx head bolt back by tranny on passenger side , that did the trick . Still have to drop tranny to finish removing oil pan . Oh well good time to replace rear main seal .
while your at it, replace the front seal on the tranny if you have the A4LD...
Just out of curiosity WHY ! Already plan on doing rear main seal . I wish I was upgrading to the HD tranny .
Rear main seal on the engine and front seal on transmission.
The why is pretty self explanatory since you are removing them.
Ray
