- Jan 23, 2014
- Pennsylvania
I'm no stranger to a stuck thermostat. I've changed one in the past soon after purchasing my truck because the engine would not heat up. As this current winter settled in I noticed the same problem. Naturally I thought the thermostat was stuck so I checked and sure enough it was. The problem is that, even though I've replaced it, the temperature will not stay warm. The gauge goes up to the middle (what I assume is the opening temperature for the thermostat which is 192 on this one) and then drops back down to C. I'm on my second brand new thermostat and the problem persists. My dad suggested it is the fan clutch so I just got a new one.
I realize I should have asked before but I'm stubborn and try to solve problems myself before asking for help. I read how a thermal fan clutch works and from what I understand it's supposed to "slip" when engine bay temperature is cool (controlled by the spring on the front) and engage when it's warmer in order to maintain proper temperature. What I observed is that even at idle the fan is going full speed in <20F degree weather. It doesn't seem to slip at all. Am I way off here or does it sound reasonable? The engine is less than 2 years old with about 14k miles on it. It got a brand new water pump before installation and a failsafe thermostat (which failed as I said). I checked the fluid levels, added antifreeze and water to top it off, checked for leaks and nothing sticks out in my mind. I'll be installing the new clutch in any case but I'd welcome any thoughts from the community.
