- Aug 25, 2013
My daily driver has an intermittent problem that is seemingly ignition or timing related.
I can start it up and drive it around just fine most days but sometimes it acts like it jumped time then for no reason starts running right again sometimes within a minute sometimes not for hours. It doesn't always die when this happens and it usually happens when it is hot but it will do it cold. It almost never does it in the winter. I've had the problem since I bought the truck a couple years ago but it's getting worse.
Here is what I have tried so far.
New exhaust (it was burned out and chunks of busted up honeycomb were plugging up the muffler)
Verified fuel system is ok
35 to 40 psi when the problem is happening (or not)
New relay/cleaned sockets
Changed filter
Dropped the tank and checked hoses
Injectors are working
Checked the fuel pressure regulator OK
Replaced spark plug wires
Checked all vacuum lines OK
Plugged off half of them while the truck was running to make sure the auxiliary components were not leaking. Still had my "timing" problem after doing this
Changed idle and TPS sensor
Replaced aftermarket ICM with Motorcraft ICM
replaced EEC
Cleaned egr, verified plugs
Cleaned CPS, cleaned the marks it reads off of
Replaced both coil packs, cleaned sockets, verified all 8 plugs fire, one that I replaced was actually bad but replacing it did NOTHING
Cleaned MAF and manifold pressure sensor
Cleaned o2 sensor (it wasn't that dirty)
Replaced the air filter (I noticed it didn't seal well and was letting dust in the intake. I fixed this yesterday)
replaced timing belt and tensioner. The tensioner was wobbly but the belt seemed ok. It had not jumped time. This is the only thing that has made ANY difference but has come nowhere close to solving my problem.
I have not replaced the spark plugs because half of them are really hard to get to but I plan on it
I have kept up on all the fluid changes
This year does not have a cam sensor
This year does not have a distributor and is fuel injected
I have never overheated the motor
When I bought this truck it was very clean and looked like it was only used for city driving 130xxx miles at the time. It now has 165xxx miles on it.
The only modifications I have made are the exhaust, a 250 amp high output alternator and a 2400 amp 110 Wh power cell. I no longer have an amp in the truck to go with these. They have not made the problem better or worse. I was having the problem before I put these in.
Until I went unplugging stuff the other day while I was running the check engine light was not on but here are the codes it throws anyways
522
539
629
566
These are tranny codes from having a computer out of an automatic in a manual truck (I was planning on switching to auto but didn't. I still have ALL the parts to do itthough). One I fixed, the e-brake switch was unplugged and one is an a/c code because I unplugged the a/c
224
223
These are related to spark and I think are a result of messing with plugs while the engine is running but they may be relevant to my problems.
Changed filter
replaced EEC
522
539
629
566
224
223
