Sgt Ex
Good deal. Ever get those shocks on I sold you?
no. All this shitty weather has me ignoring anything outside. If it is warm next week, which i don't think it is going to be, I will put them on then. If not, I will get them on after my next trip to the gorge. We are going wheeling next weekend.
Sgt Ex
Done for now. I'll add d-ring mounts and a receiver when funds allow it
Pics from yesterday...
Starting...
Sgt Ex
Letting her eat
Sgt Ex
Let her eat a little too much...
Sgt Ex
Still drove out without a winch though :smokin:
Sgt Ex
Poser
Sgt Ex
Damage report this time...
for some reason, the wheel studs stripped out the axle shaft, causing the lug nuts to loosen, and 4 of the 5 on the driver side rear to fail and snap off. I had a spare stock axle shaft that had a little twist in it, so i pulled the chromo, put the stocker in, and rode on. Then i snapped the stocker off in the diff. Called it a day.
Looking good!! What kind of traction bars do u have on your rear? Look like a single bar setup?
Thanks dude. It's a parallel 4 link.
You know, 8 lugs and full floats don't have that problem :thefinger:
SVT
ACTUALLY, the other guys were running 8 lug full floats and one broke a brake caliper, the other broke a knuckle :thefinger:
Hater. lol
SVT
Just go ahead and use 2.5 Rockwells a bypass those, after all your all know that is what it will end up in the far future any away.
Robert
posted with a burnt Peanut butter sandwich.
I ain't hatin, just been there, done that. I at least like my wheels to stay on the truck if I break a shaft...
SVT
Me too. 9" have the bearing and everything out at the end of the axle tube. I just have to remove the tire to remove the axle shaft instead of being able to just pull it out without removing it.
That's the one benefit to the 9" being semi float. I was gonna run that, but thought why pull the tire and brakes to get the shaft out, its more work. That's why I'm going with full floats from now on, 8 bolts and the shaft is out....
SVT
I'm with him ^^. You don't even need a jack for a trail repair. Just slide the axle out with the tire still on.
I'd love to have a 69 front and rear, but I'm poor. The half tonsies already have the axles, gears, and lockers, so that's what will be staying. Maybe one day I will go with something else. For now, these work. I need the exercise lugging that big ass tire around anyway.
Sgt Ex
Well, the splines are twisted.
