2.8L Chevy TBI swap
RICO9
07/2014 OTOTM Winner
SL,UT
Title says 84.
Authored, and pioneered by Cammeddrz and RICO9
Difficulty: 8.5 out of 10
Time to install: It took us 6 months but now that it's done and we've worked out the bugs, I bet we could do it in a weekend.
Disclaimer: The Ranger Station.com, The Ranger Station.com Staff, nor the original poster are responsible for you doing this modification to your vehicle. By doing this modification and following this how-to you, the installer, take full responsibility if anything is damaged or messed up. If you have questions, feel free to PM the original poster or ask in the appropriate section of The Ranger Station.com forums.
Brief Explanation:
This is a great way to covert your already durasparked 2.8 to F.I.
Tools Needed:
basic hand tools, flaring tool, various wire connectors and crimper, grinder, drill.
Parts Needed:
a complete wiring harness, computer, throttle body, and air filter housing from a GM 2.8 equipped vehicle. (I got mine from a 92 S10), electric fuel pump from an 80's Ford F150 (this is what we used but I'm sure most others would work as well), rubber fuel line, 2 universal relays and a distributor from a duraspark 2.8.
lets start with addressing why you would want to do this as opposed to the TBI writeup in the tech library ( seen here: http://www.broncoii.org/techpages/2.8fi/index.htm )
1) the ford 3.8l injection will not work with a duraspark distributor
2) the ford 3.8l injection pours too much fuel for a 2.8l which is 35% smaller displacement than the injection is designed for
3) the ford 3.8l injection requires you to jury-rig the IAC (idle air control valve) because there is no provision for it
We also figured a way to not need to change the fuel pump, and the fuel sending unit, which usually requires changing the tank because many carbureted bronco IIs have the smaller sending unit opening which will not accept an in-tank pump
by doing so we have also avoided the need for even running new fuel lines, only a return line is needed.
this will not work with a TFI distributor because the signal generated by TFI distributors is a sine-wave AC current and the gm TBI needs a square-wave (dc) signal which the duraspark distributor generates
you will need:
1) the entire engine wiring harness from a manual transmission gm 2.8l TBI vehicle (i.e. blazer, jimmy s-10, camaro , cavalier, etc.) We used a 1992
s-10
2) the throttle body
3) the ecm (engine control module)
needed sensors/modules
1) TPS (throttle position sensor) attached to TB
2) IAC (Idle air control valve) attached to TB
3) ECT (engine coolant temp)
4) Knock (optional)
5) O2 (factory ford 2.8l O2 will work)
6) gm 2.8l distributor module (from under cap)
7) EST (electronic spark timing) Module
8) Coil
9) fuel pump relays (universal is fine)
needed hardware:
1) TBI-to-2bbl adapter plate. (and necessary gaskets)
2) high pressure inline fuel pump from late '80s ford truck
3) fuel filler neck from ford explorer (for adding in return line)
5) fuel hose
6) throttle cable linkage ball from carburetor (can be purchased from parts store, or taken from carburetor)
We went to the Junkyard and pulled the parts out from the donor vehicle
the parts-pile looked like this:
2.8L Chevy TBI swap
2.8L Chevy TBI swap
2.8L Chevy TBI swap
we used the ecm pinout seen here: http://www.vessels-clan.com/jay/truck/tbipinout.htm to weed out the un needed wires, and consolidate the harness:
2.8L Chevy TBI swap
2.8L Chevy TBI swap
the wires needing to be spliced:
1) battery 12 +
2) switched 12v +
3) negative
4) fuel pump relay
5) O2 sensor
6) "crank" signal
wire connectors not needing to be spliced
1) ECT
2) IAC
3) TPS
4) EST module
5) fuel injectors
6) distributor module (7 pins total, we spliced ours anyway to clean up length)
7) MAP (manifold absolute pressure) sensor, which is usually mounted to the gm air cleaner if you want to use the gm air cleaner housing
8) knock sensor
you need to grind the back of the rivet off on the TBI linkage. once you have ground the rivet off the post will come off and leave a hole for your ball "nub"
2.8L Chevy TBI swap
2.8L Chevy TBI swap
2.8L Chevy TBI swap
2.8L Chevy TBI swap
2.8L Chevy TBI swap
we then made the TBI adapter plate
2.8L Chevy TBI swap
the spacing of the holes is slightly wider on the gm tbi
the modified Phenolic spacer:
2.8L Chevy TBI swap
the gradual modification on the top spacer:
2.8L Chevy TBI swap
with them loosely bolted together:
2.8L Chevy TBI swap
A cross-sectional view of how i used a die-grinder to modify the spacers. on the left is how the overlap was, on the right shows how i took material off 1 side of each spacer to channel the air flow smoothly, the difference was less than 1/4"
2.8L Chevy TBI swap
before criticisms fly, i deliberately left the finish rough with the die-grinder to promote atomization.
mocked up on a loose engine:
2.8L Chevy TBI swap
2.8L Chevy TBI swap
2.8L Chevy TBI swap
2.8L Chevy TBI swap
2.8L Chevy TBI swap
next is the distributor, the way it needs to be wired to the gm Distributor module like this:
2.8L Chevy TBI swap
We did not use the TFI coil, we used the gm coil which was already wired in. if you wanted to use the TFI coil you could wire it the same way.
we wanted to utilize the GM Electronic Spark Timing control, in order to do that we needed to disable the mechanical advance inside the distributor, and to disconnect the vacuum advance. If you don't do that the ecm would try to "double advance" the timing.
using the gm est made the most sense because there is not a proper port on the tbi that has venturi vacuum to properly actuate the vacuum advance on the distributor. vacuum advance will not function properly on mere manifold vacuum
Rico used safety wire, but a small tach-weld on the weights to immobilize them, anything will work, you don't need to remove the distrubutor to do this if you don't want to dick with your timing
2.8L Chevy TBI swap
next comes the fuel pump(s), what we did was use the factory ford 2.8l mechanical fuel pump to draw the fuel from the tank, and feed the high pressure pump, which we just put under the hood.
2.8L Chevy TBI swap
This is how the return line is ran. (Ford explorer filler neck which bolts in)
2.8L Chevy TBI swap
We spliced the O2 sensor into the wire on the harness.
the distributor module needs to be mounted to a heat sink in order to prevent premature failure.
Rico made this heat sink as over kill to prevent failure (which caused the demise of our first module)
2.8L Chevy TBI swap
the gm air filter housing, with attached map sensor
2.8L Chevy TBI swap
we mounted the EST module near the ECM under the dash.
2.8L Chevy TBI swap
here are our 2 universal relays that we used, one is for the system power, the second is the fuel pump relay.
2.8L Chevy TBI swap
the system power relay uses the switched ignition as a trigger, and the output goes to the ecm
the fuel pump relay uses the green/white wire from the ecm as a trigger and the output powers the electric fuel pump
the ecm uses a signal from the ignition switch to know when you are trying to start, we ran this wire (purple/white) to the post on the starter relay to get the "crank" signal
the knock sensor needs to be threaded into the pipe thread fitting on the block (antifreeze drain), or on cylinder head If you choose to utilize the knock sensor it will also retard timing in the event of pre-ignition, we chose not to use it
I have been driving this for a couple months since we finished, the only problem was from not mouting the distributor module to a heat sink. no problems have been seen since we added a heat sink
there is an "EST bypass" which when disconnected allows you to set timing that goes to the distributor module.
Awesome info.
Moved to the submission archive and submitted to the head boss to be put into the Library.
Cool thanks. Just realized that most of my photos didn't work. (at least I can't see them) I'll get it fixed. :icon_thumby:
Thank you for the way too simple return line for the fuel system. I feel kinda dumb for not looking into the "X" fuel neck, since I have the parts from about 4-5 "X"'s piled up in the barn. Time to go "digging" for the 2.8 TBI junk that I stuffed in a box years ago....
^^ you like that :D
What kinda mileage have you been getting with this setup?
I've only really driven it offroad so far so i don't really have a mileage number.
Awesome work!
Im a little confused why you didn't just run MS1 instead, was this a cheap alternative? Sounds like your just running a stock GM tune?
Really impressive.
the bore and stroke of a gm2.8, vs a ford 2.8 is near identical. and the cam profiles are extremely similar, so basically as far as the gm 2.8l ecm is concerned it is on a gm 2.8
megasquirt is lame, gm engineers designed this system to work on a 2.8. anything a dude soldered together himself, and tuned based off of forum reccomnedations won't be any better.
this was easy, pull parts from one truck put it on another. it was also pretty cheap
