99 Ranger build
Welding the shackles helps ALOT in stability. Ive done this on a few buddys rigs with positive feedback
So i have the ruff stuff 5" shackles for the rear of the front spring. I have been experincing a little shifting from side to side when i do a sharp turn one way then turn the other way right away. I know the rear spool is really pushing when im turning, which i dont mind. I also know a trac bar would fix this, but the truck handles really good other wise. Would welding the rear shackles together (like in a H) help the shifting some?
Yep! I just did this for my buddy.
Thank guys. i know what I'll be doing on my next day off!
nice build, i like what you did with power steering box. good flexand not a bad approach angle for being leaf sprung
Thanks for the compliments.
Redid my rear shackles last week, made a big difference on how it handles. will post pic later, just got back from vacation with the family.
Any pictures of the shackles yet? I am fixing to make some so I can get rid of my blocks.
I wanted to see how you did yours.
I redid my front leaf springs shackles. For my rear leaf springs i used chevy 2 in loweing shackles in place of the stock ones.
Here is a pic of my new shackle, decided not to weld them instead i put a tube in and bolted it up. It helped alot with the shifting i was getting. Still may weld them up.
99 Ranger build
Also got a front driveshaft the other day, took it to the local driveline shop to get shorten. Will be picking it up tomarrow.
looks good! thanks for posting pictures
Where did you get your rear u bolts from? Been looking all over and can't find a 13" long Dana 60 rear u bolt kit. It's all too short
sweet! you might want to swap those bolts with some grade 8's or 9's
The shop I work at keeps u-bolt rods in stock. We have a machine that bends them and dies for round top square top, ford top, and semi-round top u-bolts.
Upcoming TRS Events
Featured Ranger Based Vehicle
