- Nov 7, 2009
- White Pine, TN
I noticed your ABS warning light was on, did you figure that out? I was looking at the 2002 SportTrac wiring diagrams and it shows the ABS module plug pin 14 black/orange is a ground. I noticed you have the orange/back from the GForce Transducer tied into it, do you think that could be causing a cel? I know that the ABS Module is grounded at pin 8 and pin 24 also. Just wondering.
On his truck, the only and best way to fix the ABS light, is just to remove the bulb, on my 89 BroncoII the light was on, and instead of chasing down a new block and a new sensor and ring for the rear end, I just fixed it by removing the bulb, no more lite ABS light, no more problems, I still have great breaks.
Robert
posted using something other then tapatalk.
